Articles in this section
Plesk Update fails: Table 'mysql.innodb_index_stats' doesn't exist in engine
Plesk for Linux kb: technical
  • Plesk for Linux
  • Plesk for Windows
  • Plesk update fails due to corrupted InnoDB table(s): mysql.innodb_index_stats, mysql.innodb_table_stats, mysql.transaction_registry, mysql.gtid_slave_pos:
    CONFIG_TEXT: Error : Table 'mysql.innodb_index_stats' doesn't exist in engine
    Error : Table 'mysql.innodb_table_stats' doesn't exist in engine
    Error : Table 'mysql.transaction_registry' doesn't exist in engine
    Error : Table 'mysql.gtid_slave_pos' doesn't exist in engine
  • One of the errors above also appears when creating a database dump of the mysql database, installing SpamAssassin Spam Filter or running plesk repair db.
Corrupted InnoDB tables in the mysql database.
For Plesk on Linux
  1. Connect to the Plesk server via SSH.
  2. Create a temporary backup directory:
    # mkdir -p /root/backup_folder/
  3. Stop the MySQL/MariaDB service:
    # service mariadb stop
  4. Move the .frm and .ibd files of the corrupted table(s) that was mentioned in the error message:
    # mv /var/lib/mysql/mysql/innodb_index_stats* /root/backup_folder/
    # mv /var/lib/mysql/mysql/innodb_table_stats* /root/backup_folder/
    # mv /var/lib/mysql/mysql/transaction_registry* /root/backup_folder/
    # mv /var/lib/mysql/mysql/gtid_slave_pos.* /root/backup_folder/
  5. Start the MySQL/MariaDB service:
    # service mariadb start
  6. Access the Plesk database:
    # plesk db
  7. Switch to the MySQL/MariaDB database:
    MYSQL_LIN: MariaDB [psa]> use mysql;
  8. Remove the table(s) from the mysql database (if exists):
    MYSQL_LIN: MariaDB [mysql]> drop table innodb_index_stats;
    MYSQL_LIN: MariaDB [mysql]> drop table innodb_table_stats;
    MYSQL_LIN: MariaDB [mysql]> drop table transaction_registry;
    MYSQL_LIN: MariaDB [mysql]> drop table gtid_slave_pos;
  9. Recreate the table:
    • innodb_index_stats
      MYSQL_LIN: MariaDB [mysql]> CREATE TABLE `innodb_index_stats` (
      `database_name` varchar(64) NOT NULL,
      `table_name` varchar(199) NOT NULL,
      `index_name` varchar(64) NOT NULL,
      `last_update` timestamp NOT NULL DEFAULT current_timestamp() ON UPDATE current_timestamp(),
      `stat_name` varchar(64) NOT NULL,
      `stat_value` bigint(20) unsigned NOT NULL,
      `sample_size` bigint(20) unsigned DEFAULT NULL,
      `stat_description` varchar(1024) NOT NULL,
      PRIMARY KEY (`database_name`,`table_name`,`index_name`,`stat_name`)
      ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb3 COLLATE=utf8mb3_bin STATS_PERSISTENT=0;
    • innodb_table_stats
      MYSQL_LIN: MariaDB [mysql]> CREATE TABLE `innodb_table_stats` (
      `n_rows` bigint(20) unsigned NOT NULL,
      `clustered_index_size` bigint(20) unsigned NOT NULL,
      `sum_of_other_index_sizes` bigint(20) unsigned NOT NULL,
      PRIMARY KEY (`database_name`,`table_name`)
    • transaction_registry
      MYSQL_LIN: MariaDB [mysql]> CREATE TABLE `transaction_registry` (
      `transaction_id` bigint(20) unsigned NOT NULL,
      `commit_id` bigint(20) unsigned NOT NULL,
      `begin_timestamp` timestamp(6) NOT NULL DEFAULT '0000-00-00 00:00:00.000000',
      `commit_timestamp` timestamp(6) NOT NULL DEFAULT '0000-00-00 00:00:00.000000',
      `isolation_level` enum('READ-UNCOMMITTED','READ-COMMITTED','REPEATABLE-READ','SERIALIZABLE') NOT NULL,
      PRIMARY KEY (`transaction_id`),
      UNIQUE KEY `commit_id` (`commit_id`),
      KEY `begin_timestamp` (`begin_timestamp`),
      KEY `commit_timestamp` (`commit_timestamp`,`transaction_id`)
    • gtid_slave_pos
      MYSQL_LIN: CREATE TABLE `gtid_slave_pos` (
      `domain_id` int(10) unsigned NOT NULL,
      `sub_id` bigint(20) unsigned NOT NULL,
      `server_id` int(10) unsigned NOT NULL,
      `seq_no` bigint(20) unsigned NOT NULL,
      PRIMARY KEY (`domain_id`,`sub_id`))
      ENGINE=MyISAM DEFAULT CHARSET=utf8 COMMENT='Replication slave GTID state';
  10. Exit MySQL/MariaDB:
    MYSQL_LIN: MariaDB [mysql]> exit
  11. Restart the MySQL/MariaDB service:
    # service mariadb restart
  12. Update Plesk.
  13. Remove the temporary backup directory:
    # rm -f /root/backup_folder/
For Plesk on Windows Server
  1. Connect to the Plesk server via RDP.
  2. Start a command prompt as an Administrator.
  3. Stop PleskSQLServer service:
    C:\> net stop PleskSQLServer
  4. Open %plesk_dir%MySQL\Data\mysql in Windows Explorer.
  5. Remove the .frm and .ibd files of the corrupted table(s) that was mentioned in the error message.
  6. Start PleskSQLServer service:
    C:\> net start PleskSQLServer
  7. Access the Plesk database:
    C:\> plesk db
  8. Switch to the MySQL/MariaDB database:
    MYSQL_WIN: MariaDB [psa]> use mysql;
  9. Remove the table(s) from the mysql database (if exists):
    MYSQL_WIN: MariaDB [mysql]> drop table innodb_index_stats;
    MYSQL_WIN: MariaDB [mysql]> drop table innodb_table_stats;
    MYSQL_WIN: MariaDB [mysql]> drop table transaction_registry;
    MYSQL_WIN: MariaDB [mysql]> drop table gtid_slave_pos;
  10. Recreate the table(s):
      MYSQL_WIN: CREATE TABLE `innodb_index_stats` (
      MYSQL_WIN: CREATE TABLE `innodb_table_stats` (
      MYSQL_WIN: CREATE TABLE `transaction_registry` (
    • gtid_slave_pos
      MYSQL_WIN: CREATE TABLE `gtid_slave_pos` (
  11. Exit MySQL/MariaDB:
    MYSQL_WIN: MariaDB [mysql]> exit
  12. Restart the MySQL/MariaDB service:
  13. Update Plesk.
