Articles in this section
Unable to issue a Let's Encrypt certificate: an ASP.NET setting has been detected that does not apply in Integrated managed pipeline mode
Plesk for Windows kb: technical ext: le
  • Plesk for Windows
  • Attempting to issue a Let's Encrypt certificate for example.com domain fails with a generic 403 error:
    PLESK_ERROR: Status: 403
    Detail: Invalid response from http://example.com/.well-known/acme-challenge/WTAKI-FRel8tZZKYyhM2UfzvM9TWk02r4fZ__cjuCkU:
  • Accessing the token link from the error message via browser results in the following error:
    CONFIG_TEXT: HTTP Error 500.24 - Internal Server Error
    An ASP.NET setting has been detected that does not apply in Integrated managed pipeline mode.
    Detailed Error Information:
    Module ConfigurationValidationModule
    Notification BeginRequest
    Handler ExtensionlessUrlHandler-Integrated-4.0
    Error code 0x80070032
ASP.Net Impersonation is enabled in IIS > server_name > Authentication or in IIS > sites > example.com > Authentication.
This can also be confirmed by checking the %plesk_vhosts%example.com\httpdocs\web.config file - the following line will be present:
CONFIG_TEXT: <system.web>
<identity impersonate="true" />
</system.web>
Disable ASP.Net Impersonation in IIS:
  1. Connect to the server via RDP
  2. Navigate to IIS > server_name > Authentication or IIS > sites > example.com > Authentication
  3. Right-click the ASP.Net Impersonation setting and select Disable
If it is not possible to disable the impersonation settings due to specific website configuration, change the pipeline mode for the acme-challenge application pool:
  2. Navigate to IIS > Applications pools > acme-challenge > Basic Settings
  3. Switch Managed pipeline mode to "Classic"
