Articles in this section
Unable to repair domains in Plesk using "plesk repair db" utility: The following domains are assigned to already removed IP addresses
kb: bug kb: fixed Plesk for Linux
  • Plesk for Linux
IP address of subscriptions was changed and after that plesk repair db utility shows the error message below for domains with “Forwarding” hosting type:
# plesk repair db -n
The following domains are assigned to already removed IP addresses.
Reassign the domains to existing IP addresses:
example.com ...................................................... [ERROR]
Product issue:
  • #PPPM-13256 "Changing the IP address for a subscription now correctly updates the IP address of all domains owned by the subscription with the “Forwarding” hosting type."
    Fixed in:
Workaround
If update is not possible for some reason you may try the following
workaround
  1. Login to the server via SSH.
  2. Create backup of psa database:
    # plesk db dump > psa.sql
  3. Check what val is used for all other domains:
    # plesk db "select domains.name,dom_param.param,dom_param.val from domains, dom_param where domains.id=dom_param.dom_id and dom_param.param='ip_addr_id'"
  4. Update dom_param.val with correct value:
    # plesk db "update dom_param set val=1 where param='ip_addr_id' and val=9;"
    where 1 - is a correct value, 9 - is old wrong value.
