Articles in this section
Customize option for subscription editing is missing in Plesk interface
Plesk for Windows Plesk for Linux kb: technical
  • Plesk for Linux
  • Plesk for Windows
Customize option for subscription editing is missing in the Plesk interface.
Since Plesk 18.0.39 right sidebar is collapsed and as a consequence Customize option is hidden.
  1. Log into Plesk.
  2. Navigate to Subscriptions > example.com page and expand right sidebar menu by pressing the mceclip0.png button:
Make the sidebar expanded by default for all clients:
  2. Open the panel.ini editor:
    # plesk conf panel.ini
  3. Add the next section in there:
    CONFIG_TEXT: [navigation]
    collapseSecondarySidebar = false
  4. Update the settings for the currently registered clients using the next command:
    # plesk db "update cl_param set val='false' where param='collapsedSecondarySidebar'"
