Articles in this section
Unable to click the checkbox in the settings screen on Plesk: the Hand pointer cursor does not appear
kb: bug Plesk for Windows Plesk for Linux
  • Plesk for Linux
  • Plesk for Windows
  • The hand pointer cursor does not appear on pointing it to the checkbox
  • The Google Chrome browser is used to manage Plesk
Plesk bug #PPP-58298 "Checkboxes are clickable via labels only".
Overlapping CSS classes on Google Chrome browser:
The bug is yet to be fixed in Plesk Obsidian 18.0.47. Please track changes made in Plesk here: Change Log for Plesk Obsidian.
As a workaround, you can tick/untick the required parameter by clicking its name on right of the checkbox:
