File System check fails under Tools & Settings > Diagnose & Repair page with the error below:
PLESK_ERROR: The operation failed with the following error: {"id":1,"cmd":"plesk repair fs -n","type":"progress","message":"Checking Linux system files","level":0} {"id":2,"cmd":"plesk repair fs -n","type":"error","message":"There are incorrect permissions on some items: /var/log/plesk","level":1} {"id":3,"cmd":"plesk repair fs -n","type":"error","message":"There are incorrect permissions on some items: /opt/psa/PMM/tmp","level":1} {"id":4,"cmd":"plesk repair fs -n","type":"error","message":"There are incorrect permissions on some items: /opt/psa/PMM/rsessions","level":1} {"id":5,"cmd":"plesk repair fs -n","type":"error","message":"There are incorrect permissions on some items: /var/log/plesk/PMM","level":1}
Trying to repair File System inconsistencies at Tools & Settings > Diagnose & Repair fails with the next error:
PLESK_ERROR: 0 issue(s) fixed. 0 issue(s) detected
The following error is displayed when trying to fix permission and ownership issues with
plesk repair fstool:# plesk repair fs -y
ERROR:a bytes-like object is required, not 'str'
Product issue:
#PPPM-13691 "On Debian-based servers, the fsmng command line utility no longer fails when run."
Fixed in:- Plesk Obsidian 27 September 2022 (Linux)
Workaround
If update is not possible for some reason you may try the following
The error message is false-positive and can be safely ignored.
