Articles in this section
ASP.NET or other components installed not via Plesk are not detected at Server Components menu
kb: bug Plesk for Windows kb: fixed
  • Plesk for Windows
  • Manually enabled ASP.NET component is not displayed at Tools & Settings > Server Components page and can not be selected for domain at Domains > example.com > Hosting Settings page.
  • The same issue can be seen for other components installed/enabled not via Plesk UI.
Product issue:
  • #PPPM-13797 "Clicking Refresh on the Tools & Settings > Server Components screen now results in the list of installed components being updated as intended."
    Fixed in:
Workaround
If update is not possible for some reason you may try the following
workaround
  1. Connect to the server via RDP.
  2. Execute command below via CMD to force the components' update:
    plesk sbin defpackagemng --get --force
