Articles in this section
How to enable Queues in the Laravel project for Plesk Laravel Toolkit
DoNotDelete:docref kb: how-to Plesk Obsidian for Linux
  • Plesk for Linux
How to enable Queues in the Laravel project for Plesk Laravel Toolkit?
Note: Starting from Plesk Obsidian 18.0.80, added support for multiple named queues and multi-process execution to the Laravel extension. It is now possible to specify the number of worker processes for individual queues via the new “Number of Workers” field in the UI - handy for heavy tasks, such as sending out emails or processing payments.
To enable Queues in the Laravel project, do the following:
  1. Log in to Plesk
  2. Navigate to Domains > example.com > PHP Settings and set open_basedir = none
  3. Go to Domains > example.com > Hosting settings and set SSH Access > Type = /bin/bash
    In the scope of EXTPLESK-8895, the concept/logic for Laravel Toolkit will be reworked in one of the future Plesk updates i.e. it should work without requiring any SSH shell access
  4. Make sure that Scheduler management permission is granted for the subscription. It can be checked via Subscription > example.com > Account (on the right pane) > Customize > Permission tab
  5. Integrate the Laravel package into Plesk. In your Git project, in the “composer.json” file, add the following lines:
    CONFIG_TEXT: "require": {
    "plesk/ext-laravel-integration": "*"
    Warning: In case a local repository is used, and changes are performed via File Manager, it is required to commit changes by performing step 5 from this article.  To avoid overwriting after deploy.
  6. Select the database you want to process the queues. The following example is for MySQL database:
      5.1. Create the database
      5.2. In the “.env” project file, add the following lines:
    CONFIG_TEXT: DB_CONNECTION=mysql
    DB_HOST=<actual database_host (might be localhost)>
    QUEUE_CONNECTION=database
    DB_DATABASE=<db_name>
    DB_USERNAME=<db_username>
    DB_PASSWORD=<db_pass>
    Note: Instead of `database_host`, `db_name`, `db_username`, and `db_pass`, specify the actual values used while creating the database.
  7. Navigate to Domains > example.com > Laravel > Composer tab and run the following:
    composer update
    composer install
  8. Go to Domains > example.com > Laravel > Artisan tab and run migrate (if tables for the database are already created - this step can be skipped)
  9. Go to Domains > example.com > Laravel and enable Scheduled Tasks
  10. The Queue should now be active and ready to be enabled:
Note: In case the Queue button is still not active then SSH to domain terminal and execute this command to clear the cache:
#  php artisan config:clear
6 comments
Date Votes
  • This article gives much information about how to enable it with sql (mysql/sqllite) databases and it works really great.
    The only thing mission in the extension and in this article is the behavior of the extension. I encountered a disabled switch button if my application use a cached config file. If I remove the caching for the config the switch button is enabled (clickable again). With the environment variable from the composer package it is possible to activate the queue what isn't mentioned somewhere.
    It would be very nice if there is a better overview for the complete behavior of this extension and more information why is the switch disabled for clicks or why it is enabled.
    1
  • I have both:
    Scheduled Tasks on and the Plesk Laravel Toolkit integration package. but the button is still disabled, i can not enable it. why is that?!
    manually running php artisan queue:work in plesk
    works fine.
  • I believe this only starts one queue worker.
    Many Laravel applications have multiple queues. How do we use this task to start workers for the others?
    php artisan queue:work --name=queuename
    1
  • To enable the "queue" button, you have to un-cache the config:
    Then enable the queue, and go in SSH again and cache the config
    php artisan config:cache
  • Laravel Toolkit – “Scheduled Tasks” and “Queue” toggles are coupled for one domain (can’t disable Laravel queue while keeping Scheduler enabled)
  • Why are queued jobs run from different php than defined for the vhost? I get memory size exhausted errors because the worker runs on '/opt/plesk/php/8.3/bin/php' instead of ‘/var/www/vhosts/domain.xy/.phpenv/shims/php’
    Can this be changed?
