Articles in this section
Vulnerability CVE-2026-125396 and CVE-2026-114727 (Upload2Shell): Remote code execution via image processing in Roundcube shipped with Plesk for Linux
kb: security kb: ai-created kb: ai-edited
Situation
A security vulnerability, also known as Upload2Shell, was discovered in Ghostscript, which processes images and documents. In Plesk for Linux, it can be reached through the image processing of Roundcube Webmail, which is shipped with Plesk. This security vulnerability has been identified as CVE-2026-125396, and the related Roundcube vulnerability has been identified as CVE-2026-114727.
Affected product version
Product / Component Affected versions Patched versions
Roundcube Webmail shipped by Plesk for Linux
  • Roundcube 1.6.0 to 1.6.19
  • Plesk Obsidian 18.0.80 Update 11 and earlier
  • Plesk Obsidian 18.0.81 through Update 4
  • Roundcube 1.6.20
  • Plesk Obsidian 18.0.81 Update 5
Impact
A remote attacker may be able to run commands on the server (remote code execution, RCE) by getting a specially crafted image file processed by Roundcube.
Call to action
The fix (Roundcube 1.6.20) is already available for Plesk for Linux in the following updates:
  1. If the server runs Plesk Obsidian 18.0.80 or earlier, upgrade Plesk to the next release until it runs Plesk Obsidian 18.0.81 or later.
  2. Update Plesk to the latest available version.
  3. Check the Plesk version installed on the server and make sure it matches or is newer than the patched versions.
Updating Plesk protects the components that Plesk ships. Plesk does not update Ghostscript. CVE-2026-125396 is fixed in Ghostscript 10.08.0 and in fixed packages from operating system vendors, which must be installed through the operating system updates.
Review other software on the server that processes images or documents with Ghostscript, such as other web applications, and update accordingly. For the Ghostscript fix status and the applications found to be affected, see the Upload2Shell research by pwn.ai.
