- Incoming email does not arrive
Mail log
/var/log/maillogcontains messages similar to:Oct 20 17:36:53 plesk dovecot: lda(35096): Fatal: Plugin '$mail_plugins' not found from directory /usr/lib/dovecot/modules
Oct 20 17:36:53 plesk dovecot: lda(35099): Fatal: Plugin '$mail_plugins' not found from directory /usr/lib/dovecot/modules
Oct 20 17:36:53 plesk dovecot: lda(35101): Fatal: Plugin '$mail_plugins' not found from directory /usr/lib/dovecot/modules
Oct 20 17:36:53 plesk dovecot: lda(35103): Fatal: Plugin '$mail_plugins' not found from directory /usr/lib/dovecot/modules
Due to Dovecot syntax changes in version 2.4, the file /etc/dovecot/conf.d/15-lda.conf is no longer required.
When Postfix uses Dovecot LDA for local delivery, it calls dovecot-lda as the delivery agent.
If 15-lda.conf was misconfigured (e.g., referencing $mail_plugins incorrectly), Dovecot LDA would fail, causing Postfix to defer local deliveries.
https://doc.dovecot.org/main/installation/upgrade/2.3-to-2.4.html#plugin-settings
- Connect to the server via SSH
Rename
/etc/dovecot/conf.d/15-lda.conf# mv /etc/dovecot/conf.d/15-lda.conf /etc/dovecot/conf.d/15-lda.conf_bk
Restart Dovecot:
# systemctl restart dovecot
