Plesk pages load slowly or fail to load with the error:
PLESK_INFO: 502 Bad Gateway
A lot of messages like below may appear in
/var/log/plesk/panel.log:CONFIG_TEXT: ERR [panel.ui] You have entered incorrect username or password.
ERR [panel] [Action Log] Failed login attempt with login 'admin' from IP 203.0.113.2 -
There is a large number of sw-engine processes:
CONFIG_TEXT: # ps fax | grep sw-engine | wc -l
57 -
The top command shows that sw-cp-server process loads CPU at ~100%:
CONFIG_TEXT: PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
34409 sw-cp-s+ 20 0 58860 26840 5080 R 95.7 0.7 15:12.42 sw-cp-server: worker process -
There is a large number of network connections to Plesk panel ports from different IP addresses:
CONFIG_TEXT: # ss -tan state established | grep ":8880\|:8443" | awk '{print $4}'| cut -d':' -f1 | sort -n | uniq -c | wc -l
Plesk ports 8443 and 8880 are under a DDoS attack.
Connect to your Plesk server via SSH.
Activate Fail2Ban:
# plesk bin ip_ban --enable
Enable plesk-panel jail - it scans Plesk logs and blocks IP addresses that have failed to log in to Plesk after a specified number of attempts.
# plesk bin ip_ban --enable-jails plesk-panel
Enable recidive jail:
# plesk bin ip_ban --enable-jails recidive
Change the number of failures before the IP address is banned from 5 (default) to 3:
# plesk bin ip_ban --update -max_retries 3
Give Fail2Ban several minutes to ban unwanted IP addresses.
Check other DDoS protection tools in this KB article.
