- Unable to login to Roundcube webmail
- The following error shows when trying to access a mail account in Roundcube:
PLESK_INFO: Connection to storage server failed.
- The
dovecotservice is running. - There are no errors in the
/var/log/plesk-roundcube/errorsfile. - There are no related errors in the
/var/log/maillogfile. - The
/usr/share/psa-roundcube/config/config.inc.phpfile is the default one. - Errors like below are reported to
/var/log/httpd/error_logfile:
CONFIG_TEXT: [NOTICE] [1872] [T0] [203.0.113.2:61471-H3:BB57493EA70916C9-8#APVH_webmail.example.com:443] [STDERR] PHP Warning: stream_socket_client(): php_network_getaddresses: getaddrinfo for localhost failed: No address associated with hostname in /usr/share/psa-roundcube/program/lib/Roundcube/rcube_imap_generic.php on line 1059
[NOTICE] [1872] [T0] [203.0.113.2:61471-H3:BB57493EA70916C9-8#APVH_webmail.example.com:443] [STDERR] PHP Warning: stream_socket_client(): Unable to connect to ssl://localhost:993 (php_network_getaddresses: getaddrinfo for localhost failed: No address associated with hostname) in /usr/share/psa-roundcube/program/lib/Roundcube/rcube_imap_generic.php on line 1059
[NOTICE] [1872] [T0] [203.0.113.2:61471-H3:BB57493EA70916C9-8#APVH_webmail.example.com:443] [STDERR] PHP Warning: file_put_contents(/var/log/plesk-roundcube//errors): Failed to open stream: No such file or directory in /usr/share/psa-roundcube/program/lib/Roundcube/rcube.php on line 1380
[NOTICE] [1872] [T0] [203.0.113.2:61471-H3:BB57493EA70916C9-8#APVH_webmail.example.com:443] [STDERR] PHP Warning: Login failed for john_doe@example.com against localhost from 203.0.113.2. Could not connect to ssl://localhost:993: php_network_getaddresses: getaddrinfo for localhost failed: No address associated with hostname in /usr/share/psa-roundcube/program/lib/Roundcube/rcube.php on line 1503
- LiteSpeed is used as web-server.
Unclear issue on LiteSpeed PHP side.
Contact LiteSpeed support for further investigation of the issue.
- Log into Plesk
- Go to Extensions > LiteSpeed Extension > Open > Switch to Apache
- Connect to the server via SSH
Create
/usr/share/psa-roundcube/config/config.local.phpfile:# touch /usr/share/psa-roundcube/config/config.local.php
Set the correct permissions/ownership for the file:
# chown root:roundcube_sysgroup /usr/share/psa-roundcube/config/config.local.php
# chmod 640 /usr/share/psa-roundcube/config/config.local.php
Add the following content into /usr/share/psa-roundcube/config/config.local.php file:
CONFIG_TEXT: <?php
$config['db_dsnw'] = 'mysql://roundcube:password@127.0.0.1/roundcubemail';
$config['imap_host'] = 'ssl://127.0.0.1:993';
$config['smtp_host'] = 'ssl://127.0.0.1:465';Note: the password for db_dsnw should be copied from /usr/share/psa-roundcube/config/config.inc.php
Using vi (or other editor), open
/usr/share/psa-roundcube/config/config.inc.phpand comment outdb_dsnwvariable.
