Articles in this section
Website fails to load periodically with a 503 error. Failed to read FastCGI header
Plesk for Linux kb: technical php
  • Website fails to load periodically with a 503 error.
  • The following messages appear in domain's log:
    CONFIG_TEXT: [proxy_fcgi:error] [pid 2915996:tid 140490896815872] [client 203.0.113.2] AH01067: Failed to read FastCGI header
    [proxy_fcgi:error] [pid 2915996:tid 140490896815872] (104)Connection reset by peer: [client 203.0.113.2] AH01075: Error dispatching request to :
Some PHP-FPM processes got stuck.
Go to Domains > example.com > PHP Settings:
Change the PHP version to another and then back to the original.
