Unable to run a full (large) backup at Plesk > Tools & Settings > Backup Manager. The process starts but fails with the errors like below:
PLESK_ERROR: Unable to back up files from /var/www/vhosts/example.net owned by system user. Error: Failed to create archive: Failed to close volume: (5) Input/output error
Warning: Subscription "example.com"
Unable to back up files from /var/www/vhosts/example.com owned by system user. Error: Failed to create archive: Failed to close volume: (5) Input/output error
Warning: Database "example_db"
Unable to make database dump. Error: Failed to create archive: Failed to close volume: (5) Input/output error -
The
/var/lib/psa/dumpsdirectory is mounted on a CIFS-typed partition (in this example on 192.0.2.2 IP). OrDUMP_Dvariable points to this CIFS-storage (can be checked in/etc/psa/psa.conf). -
The following can be found in the output of
dmesg:CONFIG_TEXT: [12345.6789] CIFS VFS: Server 192.0.2.2 has not responded in 120 seconds. Reconnecting...
[98765.4321] CIFS VFS: Server 192.0.2.2 has not responded in 120 seconds. Reconnecting...
Bad connectivity between the Plesk and CIFS server.
Contact with your network administrator and/or with administrator of CIFS server for further investigation.
