Articles in this section
Plesk Update or OS conversion to AlmaLinux 8 fails on CentOS 7: EPEL repository should be enabled for PHP X.Y
kb: technical
  • Plesk for Linux
  • Plesk Update fails with the following error message in /var/log/plesk/install/autoinstaller3.log:
    CONFIG_TEXT: ERROR: Components and product validation detected at least one important issue:
    EPEL repository should be enabled for PHP 7.4
    PHP installation requires 'epel' OS repository to be enabled.
    Make sure it is available and enabled, then try again.
  • Conversion from CentOS 7 to AlmaLinux 8 fails with:
    CONFIG_TEXT: ERROR - centos2alma process has failed. Error: [Errno 2] No such file or directory: '/etc/yum.repos.d/epel.repo'
  • Installation of Plesk Email Security extension fails:
    PLESK_ERROR: Installing Amavis
    Execution filemng has failed with exit code 1, stdout: , stderr: Error: Unknown repo: 'epel'
EPEL repository is not enabled in the system.
  1. Connect to the Plesk server via SSH.
  2. Create file /etc/yum.repos.d/epel.repo:
    # touch /etc/yum.repos.d/epel.repo
  3. Open this file in a text editor. In this example, we are using vi editor:
    # vi /etc/yum.repos.d/epel.repo
  4. Add the following content there:
    CONFIG_TEXT: [epel]
    name=Extra Packages for Enterprise Linux 7 - $basearch
    # It is much more secure to use the metalink, but if you wish to use a local mirror
    # place its address here.
    #baseurl=http://download.example/pub/epel/7/$basearch
    metalink=https://mirrors.fedoraproject.org/metalink?repo=epel-7&arch=$basearch&infra=$infra&content=$contentdir
    failovermethod=priority
    enabled=1
    gpgcheck=1
    gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-EPEL-7
    [epel-debuginfo]
    name=Extra Packages for Enterprise Linux 7 - $basearch - Debug
    #baseurl=http://download.example/pub/epel/7/$basearch/debug
    metalink=https://mirrors.fedoraproject.org/metalink?repo=epel-debug-7&arch=$basearch&infra=$infra&content=$contentdir
    enabled=0
    gpgcheck=1
    [epel-source]
    name=Extra Packages for Enterprise Linux 7 - $basearch - Source
    # place it's address here.
    #baseurl=http://download.example/pub/epel/7/source/tree/
    metalink=https://mirrors.fedoraproject.org/metalink?repo=epel-source-7&arch=$basearch&infra=$infra&content=$contentdir
    enabled=0
    gpgcheck=1
  5. Save the changes and close the file.
  6. Reinstall EPEL repository:
    # yum reinstall epel-release
  7. Restart Plesk update.
