Articles in this section
Plesk migrator does not migrate some objects
Plesk for Linux kb: technical
  • An object (Database, Database user, Subscription etc...) is not migrated even if selected
  • No errors are shown for the specific object
  • In the debug.log from the migration session, the following can be found:
    CONFIG_TEXT: =|2023-02-24_13:10:42,410|D|ST1|core.safe|example.com||MigrationNoRepeatError: Failed to find imported dump XML file for subscription. Most probable reason is that dump file is not valid or corrupted. To investigate the issue it is recommended to check debug log for errors happened during "pmmcli --import-file-as-dump" operation.
    or
    CONFIG_TEXT: |2023-02-27_13:36:37,491|D|ST1|core.actions.deploy.panel_users_utils|example.com||Auxiliary user 'jdoe@example.com' for ''example'' already exist, so skip it
    =|2023-02-27_13:38:46,906|D|MT|core.runners.base|||Line 254 error: Element 'mailuser', attribute 'deployer-action': The attribute 'deployer-action' is not allowed.
Plesk Migrator extension bug with ID PMT-4938 which was fixed in version 2.26.17 of Plesk Migrator.
Update the Plesk Migrator extension.
