kb: how-to
Plesk for Linux
How to set the cgi_bin location for a domain in Plesk?
- Connect to the server via SSH
Add CGI bin directory:
# plesk bin settings --set force_separate_cgi_bin_dir=true
Set webspace root for domain:
# plesk bin site -u example.com -cgi-mode webspace
Additional information
Check force_separate_cgi_bin_dir status:
# plesk db "select * from misc where param='force_separate_cgi_bin_dir';"
Check domain's parameters:
# plesk db "select * from dom_param where param = 'cgi_bin_mode';"
