Articles in this section
How to set default index type for a domain in Plesk Obsidian
kb: how-to Plesk Obsidian for Linux Plesk Obsidian for Windows ABT: Group B
  • Plesk Obsidian for Linux
  • Plesk Obsidian for Windows
  • Plesk for Linux
  • Plesk for Windows
How to change default index type for a domain in Plesk?
Note: If the options described are not available in Plesk GUI, contact the server's administrator or the hosting support.
Note: By default, the index order sets *.html with more priority than the *.php files.
Click on a section to expand
For Plesk on Linux
  1. Log in to Plesk GUI
  2. Go to Domains > example.com > Apache & Nginx Settings > Check the option Enter custom value near Index files > Make all the required changes > Click OK to apply the changes:
For Plesk on Windows
  2. Go to Domains > example.com > IIS Settings > Check the option Enter custom value near Default documents > Make all the required changes > Click OK to apply the changes:
To change the default document for all domains, use instructions available in the following article:
How to change the default index for all websites?
