Plesk for Linux
kb: technical
Error loading module while running PHP script:
CONFIG_TEXT: PHP Warning: Module '<module_name>' already loaded in Unknown on line 0
A PHP Module is enabled several times in one of the php.ini files.
- Connect to the server via SSH
Check the
.inifiles of the PHP handler and find duplicates (replace<module_name>with the actual module name from the error):For the PHP version provided by the OS vendor:
# grep -iR '<module_name>' /etc/php/
For PHP X.X version shipped with Plesk, e.g. 8.2:
# grep -iR '<module_name>' /opt/plesk/php/X.X/etc/
For custom php.ini file for the domain:
# grep -iR '<module_name>' /var/www/vhosts/system/example.com/conf/etc/
- Comment or remove the duplicated directive line using the text editor
Plesk for Linux
Symptoms:
PHP Warning: Module '<module_name>' already loaded in Unknown on line 0Cause:
The PHP module is enabled multiple times in one or more php.ini files.
Resolution:
<module_name>with the actual module name from the error):grep -iR '<module_name>' /etc/php/grep -iR '<module_name>' /opt/plesk/php/X.X/etc/For custom php.ini files for the domain:
grep -iR '<module_name>' /var/www/vhosts/system/example.com/conf/etc/mr flip3. Use a text editor to comment out or remove the duplicated directive lines.
