Articles in this section
Logs are not being rotated for a domain in Plesk
Plesk for Linux kb: technical ABT: Group B
  • Plesk for Linux
  • Logs are not being rotated for one or several domains.
  • The date the logs of the domain example.com have been rotated last time is long ago:
    # grep example.com /usr/local/psa/var/logrotate.status
    "/var/www/vhosts/system/example.com/logs/error_log" 2019-8-28
    "/var/www/vhosts/system/example.com/logs/access_log.processed" 2019-8-28
    "/var/www/vhosts/system/example.com/logs/access_ssl_log.processed" 2019-8-28
    "/var/www/vhosts/system/example.com/logs/proxy_error_log" 2019-8-28
  • The following error might be found in /var/log/plesk/panel.log:
    CONFIG_TEXT: Log rotation '/usr/local/psa/logrotate/sbin/logrotate /usr/local/psa/etc/logrotate.conf -s /usr/local/psa/var/logrotate.status' failed with code 1.
    Stdout:
    Stderr:error: line 4332 too long in state file /usr/local/psa/var/logrotate.status
    error: could not read state file, will not attempt to write into it
The /usr/local/psa/var/logrotate.status file got corrupted.
This file is where logrotate stores information about when each log file has been last rotated.
  2. Move /usr/local/psa/var/logrotate.status file:
    # mv /usr/local/psa/var/logrotate.status /usr/local/psa/var/logrotate.status_old
  3. Run daily maintenance task is charge of statistics calculation and log rotation:
    # plesk daily ExecuteStatistics
    Note: depending of the number of domains hosted, this operation might take some time, thus consider waiting for the next automatic execution of daily tasks.
  4. Check if the logrotate.status file is successfully regenerated:
    "/var/www/vhosts/system/example.com/logs/error_log" 2020-8-28
    "/var/www/vhosts/system/example.com/logs/access_log.processed" 2020-8-28
    "/var/www/vhosts/system/example.com/logs/access_ssl_log.processed" 2020-8-28
    "/var/www/vhosts/system/example.com/logs/proxy_error_log" 2020-8-28
    When extra domains are added to the subscription, configure them by following the article How to configure log rotation for domain?
1 comment
Date Votes
  • Hi Renan Poss Moreira
    There might be a BUG where some log files are just NOT called to be rotated... as:
    /var/www/vhosts/example.com/logs/access_ssl_log
    Which seems not to-be called to be hardlinked...
