In the menu Subscriptions > example.com > Statistics (or just Statistics in Power User view), a big amount of POP3/IMAP traffic is shown.
Although, only one mail account is configured in the domains which belong to this subscription.
How to verify POP3/IMAP traffic statistics manually?
Note: the script takes mail statistics from /var/log/maillog*
files. To make it showing statistics for the last month, adjust maillog rotation in /usr/local/psa/etc/logrotate.conf
Connect to the server using SSH.
Check if the utility
bc
is installed on the server:# command -V bc
bc is /bin/bcIf the following output is returned,
bc
should be installed as per the following steps:# command -V bc
/bin/command: line 2: command: bc: not found-
For RHEL-based operating systems (CentOS, RHEL, CloudLinux):
# yum install bc
For Debian and Ubuntu:
# apt install bc
Download the script and unpack it:
# wget https://support.plesk.com/hc/article_attachments/12377959298583/verify_pop3_imap_stats.tar.gz
# tar -zxvf verify_pop3_imap_stats.tar.gz -
Execute the script:
# ./verify_pop3_imap_stats.sh
# wget https://support.plesk.com/hc/article_attachments/12377959327383/courier_traffic.tar.gz
# tar zxf courier_traffic.tar.gz -
Run the script with desired start and end dates and a domain name, if required
# ./courier_traffic.py --start 15-08 --end 22-08 --domain example.com --unit MB /var/log/maillog
Note: To see all available options run the script with
-h
option:./courier_traffic.py -h
