Articles in this section
nginx does not start automatically after a system reboot on a Plesk for Linux server: 99: Cannot assign requested address
Plesk for Linux kb: technical
  • Plesk for Linux
  • After system reboot, the websites do not load with the error:
    PLESK_INFO: ERR_ADDRESS_UNREACHABLE
  • nginx service is in the failed state:
    # service nginx status
      Active: failed (Result: exit-code)
    server.edhub.net nginx[1104]: nginx: [emerg] bind() to [2400:8901::f03c:91ff:fe24:7893]:443 failed (99: Cannot assign requested address)
  • Manual restart of the service is successful:
    # service nginx start
    # service nginx status | grep Active
    Redirecting to /bin/systemctl status nginx.service
        Active: active (running)
During the system boot, nginx service was started before IP addresses were assigned to the network interface.
RHEL/AlmaLinux-based distributions
  1. Connect to your Plesk server via SSH.
  2. Verify that network interfaces are enabled on system boot:
    # grep -r "ONBOOT" /etc/sysconfig/network-scripts/ifcfg-*
    /etc/sysconfig/network-scripts/ifcfg-lo:ONBOOT=yes
    /etc/sysconfig/network-scripts/ifcfg-venet0:ONBOOT=yes
    /etc/sysconfig/network-scripts/ifcfg-venet0:0:ONBOOT=yes
  3. Create a copy of the nginx startup script /etc/systemd/system/multi-user.target.wants/nginx.service:
    # cp /etc/systemd/system/multi-user.target.wants/nginx.service{,.bak}
  4. Install the systemd-networkd package, if it is not installed:
    # yum install systemd-networkd
  5. Open nginx startup script in a text editor. For example, vi editor:
    # vi /etc/systemd/system/multi-user.target.wants/nginx.service
  6. Add the following line to the [Unit] section:
    CONFIG_TEXT: After=network-online.target remote-fs.target nss-lookup.target
  7. Save the changes and close the file.
  8. Reboot the server:
    # reboot
Debian/Ubuntu-based distributions
    # grep auto /etc/network/interfaces
    # This configuration file is auto-generated.
    auto lo
    auto venet0
    auto venet0:0
  4. Open nginx startup script in a text editor. For example, vi editor:
  5. Add the following line to the [Unit] section:
  6. Save the changes and close the file.
  7. Reboot the server:
    # reboot
  8. Check nginx status:
If nginx service did not start after the system restart with the new changes, apply additional step:
  1. Add the following line in [Service] section in /etc/systemd/system/multi-user.target.wants/nginx.service file:
    CONFIG_TEXT: ExecStartPre=/bin/sleep 10
    Note: Increase the value, if 10 seconds timeout is insufficient.
  2. Reboot the server:
    # reboot
