Articles in this section
How to prevent filesystem browsing with php shell scripts?
kb: how-to Plesk for Linux ABT: Group A
  • Plesk for Linux
PHP shell script was uploaded under the home directory of subscription.
It's possible to disable shell_exec and other functions in PHP by using the disable_functions directive:
Warning: Applications may rely on these functions and may not work properly when restrictions are applied.
For Plesk Onyx 17.8 and newer
  1. Login to Plesk
  2. Navigate to Domains > example.com > PHP Settings
  3. Set the following value to the disable_functions:
    CONFIG_TEXT: opcache_get_status,exec,passthru,shell_exec,system,proc_open,popen
    Note: To set the restriction to multiple domains at once, this value can be specified in Service Plans > <service_plan> > PHP Settings > disable_functions, or apply it globally for a PHP handler as specified in this article.
For Plesk Onyx 17.5 and older
  1. Login to Plesk
  3. Add the following line under Additional configuration directives and apply the changes:
    CONFIG_TEXT: disable_functions=opcache_get_status,exec,passthru,shell_exec,system,proc_open,popen
