Articles in this section
Vulnerability CVE-2026-44962 in Plesk's APS Catalog
  • Plesk for Linux
Situation
A security vulnerability allowing local privileges escalation was discovered in search functionality of Plesk's APS Catalog. This security vulnerability has been identified as CVE-2026-44962.
Affected product version
Product Affected versions Patched verions Unaffected versions
Plesk Obsidian 18.x
Below 18.0.75.1
18.0.75.1
18.0.76.2 and later
Impact
Local privilege escalation (LPE) is possible.
Call to action
On February 24 and 25, 2026, the Plesk Team published fixed versions of Plesk: 18.0.76.2 and 18.0.75.1.
Update Plesk to install it by following the steps from this guide: How to install Plesk updates
Mitigation
If upgrading is not possible at the moment, apply the workaround below by adding the below section into the /usr/local/psa/admin/conf/panel.ini file.
CONFIG_TEXT: [aps]
enabled = off
Acknowledgements
We would like to thank Georgii Shutiaev for responsibly disclosing this vulnerability and working with us to help protect our customers.
1 comment
Date Votes
  • The advisory stresses updating to the fixed version promptly to avoid exploitation and ensuring your system is patched with the latest security updates.
    MyPrepaidCenter account
