The following error message appears in the Plesk interface or during Plesk migration process:
Unable to connect to database: Too many connections
SQLSTATE[08004] [1040] Too many connections
ODBC error #HY000: [unixODBC][ma-3.0.8]Too many connections
Websites fail to load with the error:
Error Establishing a Database Connection
Plesk license installation fails with the error:
Incorrect ServerInfo format (Error code: 2)
exit status 1
The maximum number of simultaneous connections to the MySQL server has been reached and new connections to the server cannot be established.
Note: On Linux server with MySQL installed, the max_connections
limit cannot be higher than 214, unless the solution from this KB article is applied.
# Automatic Solution
Download the script that will set the MySQL parameter
max_connections
to 300:# wget https://raw.githubusercontent.com/plesk/kb-scripts/master/mysql-max-connections/mysql-max-connections.sh
Make the script executable:
# chmod +x mysql-max-connections.sh
Execute the script:
# ./mysql-max-connections.sh
Note: If the automatic solution did not help, apply the manual solution below.
# Manual Solution
Find the current
max_connections
value:# plesk db "SHOW VARIABLES LIKE 'max_connections'"
| Variable_name | Value |
| max_connections | 151 |
Open the MySQL configuration file
my.cnf
in a text editor. In this example, we are using the vi editor:-
on CentOS/RHEL-based distributions
# vi /etc/my.cnf
on Debian/Ubuntu-based distributions
# vi /etc/mysql/my.cnf
Increase the number of connections by adding this directive under the
[MySQLD]
section:[mysqld]
max_connections=300 -
Save the changes and close the file.
Restart MySQL/MariaDB service to apply the changes using one of these commands:
# service mysql restart
# service mariadb restart
Connect to the Plesk server via RDP.
%plesk_dir%Databases\MySQL\my.ini
in a text editor. -
[MySQLD]
section (the default value is 300):[MySQLD]
Restart the MySQL/MariaDB service Plesk Management Service using Windows Plesk Services Monitor
