Articles in this section
Mailing list archives and settings are not transferred by Plesk Migrator
Plesk for Linux kb: technical ext: migrator ABT: Group B
  • Plesk for Linux
Advanced settings of mailing lists and Mailman archives are not transferred by Plesk Migrator.
Plesk Migrator transfers only basic settings of mailing lists: list administrator, subscribers. Mailing list archives and other settings are not transferred as Plesk does not manage them.
It is possible to transfer configuration of mailing list(s) using Mailman's config_list utility.
Transferring configuration of one mailing list
Below example shows how to transfer the settings of the mailing list mail_list1 from a source server to destination:
  1. Connect to the source Plesk server via SSH.
  2. Save the mailing list configuration into the file mail_list1.conf:
    # /usr/lib/mailman/bin/config_list -o mail_list1.conf maillist1
  3. Transfer mail_list1.conf to the destination server, where domain with mailing list has already been migrated, and restore the configuration:
    # /usr/lib/mailman/bin/config_list -i mail_list1.conf mail_list1
Transferring configuration of all mailing lists
  2. Create a folder for the configuration files and open it:
    # mkdir /root/list_configs && cd /root/list_configs
  3. Create configuration backups for all mailing lists:
    # for i in $(ls /var/lib/mailman/lists/ |grep -v mailman); do /usr/lib/mailman/bin/config_list -o $i.conf $i;done
  4. Connect to the destination Plesk server via SSH and create the same directory:
  5. Copy the files from the source Plesk server to the destination server.
  6. Restore the mailing lists' configuration:
    # for i in $(ls);do /usr/lib/mailman/bin/config_list -i $i `ls $i| cut -d. -f1` ;done
