Webmail:
Roundcube/Horde webmail shows the following error message in a web browser:
CONFIG_TEXT: Service Temporarily Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Apache Server at webmail.example.com Port 80
CONFIG_TEXT: 500 Internal Server Error
The following messages appear in
/var/log/psa-horde/psa-horde.logor/var/log/apache2/error.log:CONFIG_TEXT: [warn] [client 203.0.113.2] (104)Connection reset by peer: mod_fcgid: error reading data from FastCGI server
[error] [client 203.0.113.2] Premature end of script headers: index.php -
The following error messages may appear in
/var/log/httpd/suexec_log:CONFIG_TEXT: uid: (10021/horde_sysuser) gid: (510/510) cmd: cgi_wrapper
target uid/gid (10021/510 or 504) mismatch with directory (0/503) or program (0/0)
uid: (2523/horde_sysuser) gid: (2521/2521) cmd: cgi_wrapper
directory is writable by others: (/var/www/cgi-bin/cgi_wrapper)
CONFIG_TEXT: uid: (996/roundcube_sysuser) gid: (1006/1006) cmd: cgi_wrapper
file has no execute permission: (/var/www/cgi-bin/cgi_wrapper/cgi_wrapper)
Websites on FastCGI:
Websites served by the PHP FastCGI handler are not loading with a 500 error. After changing a PHP handler to PHP-FPM, websites start to work.
CGI scripts do not work on a website.
- Following error messages in
/var/www/vhosts/system/example.com/logs/error_log:CONFIG_TEXT: [warn] [client 203.0.113.2] (104)Connection reset by peer: mod_fcgid: error reading data from FastCGI server
Plesk migration:
The following warning appears during a Plesk migration:
PLESK_WARN: WARNING:()The webmail service horde is unavailable. It will be replaced with <webmail> for the following objects: <list of domains>
Permissions on the file /var/www/cgi-bin/cgi_wrapper are incorrect.
Connect to the server via SSH
Correct the permissions:
# chown root:root /var/www
# chmod 0755 /var/www
# chown -R root:root /var/www/cgi-bin
# chmod 0755 /var/www/cgi-bin
# chmod -R 0755 /var/www/cgi-bin/cgi_wrapper
