Articles in this section
Unable to swap domain and domain alias names: boost::filesystem::filesystem_error Directory not empty
Plesk for Linux kb: technical ABT: Group A
  • Plesk for Linux
  • Unable to swap domain and domain alias names in Plesk with the error below:
    PLESK_ERROR: Error: mailmng-core failed: mailmng[23434]: Mail directory /var/qmail/mailnames/example.com already exists
  • The following can be found in /var/log/plesk/panel.log:
    CONFIG_TEXT: ERR [util_exec] proc_close() failed ['/opt/psa/admin/bin/mailmng-core' '--rename-domain' '--old-domain-name=domain-example.com' '--new-domain-name=alias-example.com'] with exit code [1]
    ERR [1] '/opt/psa/admin/bin/mailmng-core' '--rename-domain' '--old-domain-name=domain-example.com' '--new-domain-name=alias-example.com' failed with code 1. stdout: Fatal error: boost::filesystem::filesystem_error(boost::filesystem::rename: Directory not empty: "/var/qmail/mailnames/domain-example.com", /var/qmail/mailnames/alias-example.com)
Mail directory for the alias is not empty.
In order to archive the goal to swap domain and domain alias names remove incorrect folder for alias:
  1. Connect to the server via SSH.
    Note: Let's assume that domain-example.com is a domain name and alias-example.com is an alias.
  2. Move current mailnames folder for alias to another directory as a backup:
    # mv /var/qmail/mailnames/alias-example.com/ ~/alias-example.com/
  3. If /var/qmail/mailnames/domain-example.com does not exist, copy backed up mail directory:
    # mkdir /var/qmail/mailnames/domain-example.com
    # cp -p ~/alias-example.com/* /var/qmail/mailnames/domain-example.com/
  4. Rename the domain.
Additional information
Unable to rename a domain: mailmng-outgoing failed: ERROR:outgoing:No backend DB entries were modified
