Plesk for Windows
Plesk for Linux
kb: technical
ext: wptk
ABT: Group B
- Plesk for Windows
A WordPress website is not accessible. One of the following errors is shown in a browser:
PLESK_INFO: The page isn't redirecting properly
or
PLESK_INFO: ERR_TOO_MANY_REDIRECTS
- In Mozilla Web Console or Chrome Web Inspector there are endless redirects from www.example.com to example.com and vice versa.
- The solution from this KB article did not help.
Invalid WordPress configuration.
- Log into Plesk.
- In Plesk go to Domains > example.com and click File Manager and open the file wp-config.php.
Add the code below at the bottom of the file right before
?>:CONFIG_TEXT: define('WP_HOME','http://www.example.com');
define('WP_SITEURL','http://www.example.com'); -
If the issue still occurs, open the file _wp-config.php _and change the records to records the below:
CONFIG_TEXT: define('WP_HOME','http://example.com');
define('WP_SITEURL','http://example.com');Note: This can also be done via Domains > example.com > Wordpress > Log in > Settings > General > WordPress Address (URL) and Site Address (URL).
- Rename plugins directory via Domains > example.com > File Manager (
wp-content/pluginsdirectory) or disable WordPress plugins one by one to find the faulty one.
