How to configure AWStats to show visitor's country?
By default, AWStats does not show visitors by countries.
If you wish to see this functionality in AWStats for Plesk, please submit a feature request on our Product Roadmap page:
To enable this feature manually, configure the GeoIP plugin as follows:
- Connect to your Plesk server via SSH.
Install
perl-CPANpackage:# yum install perl-CPAN
Install the GeoIP module using these two commands:
# perl -MCPAN -e "install Geo::IP::PurePerl"
# perl -MCPAN -e "install Geo::IP"
Run these commands to uncomment the plugin in AWStats configuration files:
# /bin/sed -ire '/GeoIP.dat/ s/^#//' /etc/awstats/awstats.conf
# /bin/sed -ire '/GeoIP.dat/ s/^#//' /etc/awstats/awstats.model.conf
Run these commands to correct the path:
# /bin/sed -i 's/\/pathto\/GeoIP.dat/\/usr\/share\/GeoIP\/GeoIP.dat/g' /etc/awstats/awstats.conf
# /bin/sed -i 's/\/pathto\/GeoIP.dat/\/usr\/share\/GeoIP\/GeoIP.dat/g' /etc/awstats/awstats.model.conf
Run this command to uncomment the line for all existing domains which are using AWstats:
# for file in /usr/local/psa/etc/awstats/*; do /bin/sed -ire '/GeoIP.dat/ s/^#//' "$file"; echo "$file is updated"; done
Run this command to correct path to GeoIP plugin:
# for file in /usr/local/psa/etc/awstats/*; do /bin/sed -i 's/\/pathto\/GeoIP.dat/\/usr\/share\/GeoIP\/GeoIP.dat/g' "$file"; echo "$file is updated"; done
Recalculate web statistics for all existing domains:
# plesk sbin statistics --generate-all-webstat
# plesk sbin statistics --calculate-all
Check if the
makeutility is installed on the server:# which make
If this command's output is empty, install the required package:
# apt-get install make
Install the GeoIP module:
Hi Nikita Zubovich,
Can you please adjust the instructions, for achieveing the GEOIP on AWStats, when the GEOIP databas exists on the server, on *.dat or *.mmdb filetypes?
Such an adjustment, may relay on:
https://www.prosoxi.com/2009/01/27/geoip-filter-awstat-plesk/
If you want to use AWStats in applicable extent, you have to copy the javascript to every site on your server and include the following line into your index:
You can find the javascript here: /home/admispconfig/ispconfig/tools/awstats-6.5/wwwroot/js
Run the AWStats-script to create the statistic-files
First install the software :
