- Plesk for Windows
How to allow or forbid customers or resellers to edit PHP settings in Plesk?
The following permissions and their status (enabled or disabled) control the management of PHP settings in the personal Plesk GUI of Plesk Reseller and Customer accounts:
- Hosting settings management
- Common PHP settings management
- PHP version and handler management
You can either enabled or disable these permissions on the Subscription or Service plan level in order to achieve the desired end result by following these steps:
Note: The feature to allow or forbid access to only some particular PHP parameters (like open_basedir) is yet to be implemented, however if you would like to see such a feature become available in the future, you should take part in our product improvement efforts by pressing on Submit idea and describing your request in detail via the following page:
https://features.plesk.com/tabs/28-planned-roadmap
Note: In order for the changes that you make to actually get applied to all Subscriptions under the chosen Service plan, you must first make sure that the Subscriptions are not Locked for synchronization with their Service plans
1. Log into Plesk and go to Service Plans in order to grant or revoke permissions:
- for Plesk Customers: Service Plans > plan_name > Permissions tab.
- for Plesk Resellers: Service Plans > Reseller Plans tab > plan_name > Permissions tab.
2. Enable (or disable to forbid) the following permissions to allow PHP management:
3. Click Update & Sync.
1. Log into Plesk and go to Customers > customer_name > Subscriptions tab > subscription_name > Customize (under Account on the right).
2. On the Customizing Subscription page, switch to the Permissions tab and enable (or disable to forbid) the following permissions to allow PHP management:
3. Click Update & Lock to apply the changes.
Note: Once you Lock it, the Subscription will no longer be synchronized with its Service plan settings and parameters, due to which any changes that you make the Service plan will no longer be applied to this Subscription.
1. Log into Plesk and go to Resellers > reseller_name > Customize (under Resources on the right).
Note: Once you Lock it, the Reseller plan will no longer be synchronized with its Service plan settings and parameters, due to which any changes that you make the Service plan will no longer be applied to it.
