After upgrading MariaDB, the MariaDB service fails to start with the following error message in
/var/log/mariadb/mariadb.logor/var/log/mysql/error.log:CONFIG_TEXT: [Note] InnoDB: Starting shutdown...
[ERROR] Plugin 'InnoDB' init function returned error.
[ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
[Note] Plugin 'FEEDBACK' is disabled.
[ERROR] Unknown/unsupported storage engine: InnoDB
[ERROR] Abortingor MariaDB service returns the following error:
# service mariadb status
ERROR! MariaDB is running but PID file could not be found -
The same error may appear during Plesk upgrade or update.
MariaDB database server was not properly upgraded.
- Connect to the Plesk server via SSH
Shut down MariaDB service:
# mysqladmin -uadmin -p`cat /etc/psa/.psa.shadow` -h127.0.0.1 --protocol=tcp shutdown
Remove the incorrect service script and reload systemctl configuration:
# rm -f /etc/init.d/mysql && systemctl daemon-reload
Start the MariaDB service:
# systemctl restart mariadb
Enable MariaDB service start on boot:
# systemctl enable mariadb
