Articles in this section
Node.js/Ruby applications do not work if CageFS is enabled for the subscription user
Plesk Obsidian for Linux ABT: Group A Plesk Onyx 17.8 for Linux Plesk Onyx 17.5 for Linux
  • Plesk Onyx 17.0 for Linux
  • Plesk Onyx 17.5 for Linux
  • Plesk Onyx 17.8 for Linux
  • Plesk Obsidian for Linux
Note: This article has the reference to the issue with the fix available:
  • CloudLinux 6 or 7 is used on the server
  • CageFS is enabled for the subscription's user in Extensions > My Extensions > CageFS > Open
  • HTTP code 500 is returned by the website with the application deployed on it:
    # curl -skIL https://node.example.com/
    HTTP/1.1 500 Internal Server Error
    Server: nginx
    Date: Tue, 23 Apr 2019 04:30:29 GMT
    Status: 500 Internal Server Error
  • The following error can be found on the page on attempt to open it:
    CONFIG_TEXT: We're sorry, but something went wrong.
    The issue has been logged for investigation. Please try again later.
    CONFIG_TEXT: Web application could not be started by the Phusion Passenger application server.
  • The following error messages can be found in the Apache Web Server log file /var/log/httpd/error_log, or in nginx log file /var/log/nginx/error.log:
    CONFIG_TEXT: [ E 2019-07-04 05:05:57.4448 42423/Tb age/Cor/App/Implementation.cpp:221 ]: Could not spawn process for application /var/www/vhosts/example.com/httpdocs: The application process exited prematurely.
    Error ID: 2daff851
    Error details saved to: /tmp/passenger-error-jmYMVA.html
    [ E 2019-07-04 05:05:57.4534 42423/T5 age/Cor/Con/CheckoutSession.cpp:276 ]: [Client 1-1] Cannot checkout session because a spawning error occurred. The identifier of the error is 2daff851. Please see earlier logs for details about the error.
  • Following can be found in /tmp/systemd-private-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx-httpd.service-XXXXXX/tmp/passenger-error-XXXXXX.html, or /tmp/passenger-error-XXXXXX.html:
    CONFIG_TEXT: "stdout_and_err" : "Warning: cannot open /tmp/passenger.spawn.XXXXh6sP7q/envdump/user_info for writing\nWarning: cannot open /tmp/passenger.spawn.XXXXh6sP7q/envdump/envvars for writing\nWarning: cannot open /tmp/passenger.spawn.XXXXh6sP7q/envdump/user_info for writing\n
Phusion Passenger creates a socket to communicate with Node.js and Ruby applications in /tmp/ directory. This directory is overridden by the private per-user /tmp/ created by CageFS.
Configure NodeJS to work with CageFS.
