Articles in this section
How to adjust an IIS application pool in Plesk?
Plesk for Windows kb: how-to ABT: Group A
  • Plesk for Windows
How to protect the sites from each other so that one site cant affect performance/availability the other sites?
  1. Log into Plesk.
  2. Go to Domains > example.com > Dedicated IIS Application Pool for Website.
  3. Set Maximum CPU usage (%) limit.
  4. Select Limit action that IIS performs when a worker process exceeds the configured maximum CPU usage.
  5. Set Limit interval (minutes) to specify the reset period for monitoring of CPU usage on an application pool at option.
Example:
Note: Actual values depend on server configuration and can be based on previous performance monitoring results.
