Plesk for Windows
Plesk for Linux
kb: technical
ABT: Group A
- Plesk for Windows
The website is not accessible. The following error is shown in the browser screen:
PLESK_INFO: PHP Max Input Vars: [?] 1000 - Recommended Value: 3000. Max input vars limitation truncate POST data such as menus. Increasing max input vars limit needed.
Default value for max_input_vars directive is insufficient.
Increase
max_input_varsparameter in Domains > example.com > PHP Settings > Additional configuration directives:
NOTE: If there is no Additional configuration directives in PHP settings, contact your system administrator.
Hi, so if i nead to incease the upload_max_filesize for exemple, i just nead to tape : upload_max_filesize = 64M ?
Seems that it's not correct on my side. So may i ask how to increase this value ?
Thank's for your help
Hi Denis,
You can set up upload_max_filesize on a domain level via dropdown menu in PHP settings:
