IMAP accounts are failing to sync when using the Outlook mail client.
The Postfix service stops sending/receiving emails on port 587.
The following error can be found on
/var/log/maillog:CONFIG_TEXT: postfix/smtpd[12664]: warning: Connection concurrency limit exceeded: 51 from unknown [203.0.113.1] for service smtp
The maximum number of connections that an SMTP client may make simultaneously is exceeded (default is 50).
Either of the following resolutions can be applied:
Connect to the server using SSH
Execute the command below to increase the maximum number of connections that an SMTP client may make simultaneously:
# postconf smtpd_client_connection_count_limit=100
Note: This is a sample value, it needs to be changed according to the server specifics.
Go to Plesk > Tools & Settings > IP Address Banning (Fail2Ban) >Jails > Add Jail
Add the following:
Name:
CONFIG_TEXT: postfix-concurrency
Filter:
CONFIG_TEXT: postfix-sasl -Postfix SMTP and SASL authentication failures \
Action:
CONFIG_TEXT: iptables-multiport[name="postfix-concurrency", port="smtp,smtps,submission" protocol="tcp"]
Log Path:
CONFIG_TEXT: /var/log/maillog
Ban Period:
CONFIG_TEXT: 600
The maximum number of failed login attempts:
CONFIG_TEXT: 5
Go to Tools & Settings > IP Address Banning (Fail2Ban) >Jails > Manage Filters > Add Filter
Add the following:
Name:
Content:
CONFIG_TEXT: [Definition]
failregex = warning: Connection concurrency limit exceeded: [0-9]+ from \S+\[<HOST>\] for service \S+$
ignoreregex = -
Verify the filter functionality by running the following command:
# fail2ban-regex /var/log/maillog /etc/fail2ban/filter.d/postfix-concurrency.local
If the configuration is correct you will get a result similar to the one below:
CONFIG_TEXT: Running tests
Use failregex filter file : postfix-concurrency, basedir: /etc/fail2ban
Use log file : /var/log/maillog
Use encoding : UTF-8
Results
Failregex: 0 total
Ignoreregex: 0 total
