Articles in this section
Plesk migration fails or website not accessible: There is a duplicate section defined
Plesk for Windows kb: technical ext: migrator ABT: Group B
  • Plesk for Windows
  • Plesk Migration fails with error:
    PLESK_ERROR: example.com
    stdout: Filename: \\?\D:\Inetpub\vhosts\example.com\httpdocs\web.config
    Line number: 10
    Error: There is a duplicate 'example' section defined
  • Cannot create domain backup in Plesk:
    PLESK_ERROR: Unable to back up configuration of error documents.
    Error: Failed to exec websrvmng:
    Exit code: 1: Filename: \\?\C:\Inetpub\vhosts\example.com\web.config
    Line number: 6 Error: There is a duplicate 'system.web.extensions/scripting/scriptResourceHandler' section defined
  • An attempt to run plesk repair web example.com fails and website becomes not accessible:
    CONFIG_TEXT: HTTP Error 500.19 - Internal Server Error
    Config Error: There is a duplicate 'system.web.extensions/scripting/scriptResourceHandler' section defined
    Config File: \\?\D:\Inetpub\vhosts\example.com\custom_dir\testdatabase\web.config
    Config Source:
    13: <sectionGroup name="scripting" type="System.Web.Configuration.ScriptingSectionGroup, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=*********">
There is a duplicate section in the web.config file and in the upper-level configuration file.
  1. Log in to source Plesk panel
  2. Go to Domains > example.com > File Manager
  3. Open the file mentioned in the error message using a text editor and comment out the duplicate line of the mentioned number by
    <!-- at the beginning
    and --> at the end of the line.
    For example:
    CONFIG_TEXT: <!-- <sectionGroup name="scripting" type="System.Web.Configuration.ScriptingSectionGroup, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=*********"> -->
