Articles in this section
Redirection rules and other settings configured in the .htaccess file do not work on a website in Plesk for Linux
Plesk for Linux kb: technical ABT: Group B
  • Plesk for Linux
  • Redirection rules and other settings defined in .htaccess file are not applied on a website in Plesk for Linux
  • It is not possible to choose PHP handler served by Apache in Plesk > Domains > example.com > PHP settings;
The option Proxy mode is turned off in Domains > example.com > Apache & nginx Settings > nginx settings
When the Proxy mode is disabled, Apache is turned off and the site will be handled by Nginx which doesn't work with .htaccess files
Apply the following solution:
Turn on the Nginx Proxy mode
  1. Log in to Plesk GUI
  2. Go to Domains > example.com > Apache & nginx Settings > nginx settings > Enable the option Proxy mode > Click OK to apply the changes
1 comment
Date Votes
  • Hello
    The htaccess to nginx extension is not available anymore.
