Articles in this section
How to whitelist IP addresses for ModSecurity in Plesk?
Plesk for Windows kb: how-to Plesk for Linux ABT: Group B
  • Plesk For Windows
  • Plesk for Linux
  • Plesk for Windows
How to whitelist a single/multiple IP addresses for ModSecurity in Plesk?
Apply one of the solutions below:
For OWASP ruleset on Linux
  1. Connect to the server via SSH.
  2. Create/ open for editing ModSecurity file that is used for IP whitelisting:
    For Debian based systems (Ubuntu/Debian):
    # vi /etc/apache2/modsecurity.d/000ipwhitelist.conf
    For RHEL based systems (CentOS/CloudLinux):
    # vi /etc/httpd/conf/modsecurity.d/rules/000ipwhitelist.conf
  3. Add the following rule in 1 line there:
    CONFIG_TEXT: SecRule REMOTE_ADDR "@ipMatch 203.0.113.0/24,192.0.2.2" "id:3,phase:1,t:none,log,pass,ctl:ruleRemoveById=55666"
    Where:
    55666 - is the existing ModSecurity Rule and it should be replaced with the required rule ID.
    203.0.113.0/24 - IP addresses that are required to whitelist. Multiple, comma-separated, addresses can be also specified.
  4. Check Apache syntax:
    # apache2ctl -t
    # httpd -t
  5. If, in accordance with step #4, the syntax is not OK, fix it. If it is OK, apply the new configuration:
    # service apache2 reload
    # service httpd reload
Note: Whitelist rules should be placed before other rules.
For details see:
ModSecurity Core Ruleset documentation - Writing Whitelist Modifications
https://github.com/SpiderLabs/ModSecurity/wiki/Reference-Manual-%28v2.x%29#ipMatch
For OWASP ruleset on Windows
    1. Log into the Plesk.
    2. Go to Tools & Settings > Web Application Firewall (ModSecurity) >Settings.
    3.  Add the rule below into the Custom directives field:
      Where:
    4. Press the OK button to apply the changes.
For Comodo ruleset
  • Via Plesk GUI
  2. Go to Tools & Settings > Web Application Firewall (ModSecurity) > Settings.
    Where:
  • Using command-line method
    # vi /etc/apache2/plesk.conf.d/modsecurity.conf
    # vi /etc/httpd/conf/plesk.conf.d/modsecurity.conf
    Where:
    # apache2ctl -t
    # httpd -t
    For details see:
2 comments
Date Votes
  • You missed NGINX here. We use NGINX Hosting.
  • If you want to whitelist IP addresses and totally disable ModSecurity, the approach above doesn't work!
    Entering the exception under WAF --> Settings --> Custom directives does not work, as the settings are written to /etc/apache2/plesk.conf.d/modsecurity.conf. However, this file is only loaded by Apache after the files from /etc/apache2/modsecurity.d. are processed. As a result, the rule never takes effect!
    Instead, we can create a file /etc/apache2/modsecurity.d/custom_rules.conf.
    #Do not filter
    #With log for debugging
    SecRule REMOTE_ADDR “@IPMatch 1.2.3.4” “id:1,phase:1,t:none,pass,log,ctl:ruleEngine=Off”
    #Without log for production
    SecRule REMOTE_ADDR “@IPMatch 1.2.3.4” “id:1,phase:1,t:none,pass,nolog,ctl:ruleEngine=Off”
    A reload must then be performed for Apache:
    systemctl reload apache2.service
