Plesk for Windows
kb: how-to
Plesk for Linux
ABT: Group A
- Plesk for Windows
How to set up mail forwarding for incoming emails?
Go to Domains > example.com > Mail > Mail Accounts > john.doe@example.com > Forwarding tab
Select the Switch on mail forwarding checkbox.
Specify one or several email addresses to which email must be forwarded. When specifying email addresses, separate them with white spaces, commas, semicolons, or type each of them on a new line.
Note: Email will be stored in mailbox and another copy will be sent to forwarded mailbox.
If you do not want to keep copies of forwarded messages in the mailbox, check Do not deliver copies of forwarded emails to the Plesk mailbox, and click OK:
doesn't match available options.
