Is it possible to configure multi-factor authentication (MFA) to access Plesk?
3 comments
    Nikolay K
    How to change 16 symbol secret key for google authenticator to a new one?
    After disabling plugin and reenabling it, key is the same.
    Just in case when device with otp generator was lost, compromised or whatever
    1
    eCom Seller
    It's pretty crazy that in 2024 Plesk still can't do enforced 2fa, AND can't even do any 2fa on sub accounts (webmaster, etc.).
    Jay Dubinsky
    The extension is not called MFA anymore in plesk. If you're looking like a maniac clicking around, install the Google Authenticator extension.
