Articles in this section
CGI scripts in Plesk do not work on domain with application installed from Application Catalog: script not found or unable to stat
Plesk for Linux kb: technical ABT: Group B
  • Plesk for Linux
  • CGI scripts do not work on a domain if there is an application (e.g. WordPress) installed via the Plesk Application Catalog (either through Tools & Settings > Application Vault or Domains > example.com > Applications) to the Document Root of the domain.
  • CGI support is enabled in Domains > example.com > Hosting Settings.
  • CGI directory location it automatically detected as /usr/lib/cgi-bin/. The following error might be found in /var/www/vhosts/system/example.com/logs/error.log:
    CONFIG_TEXT: [cgi:error] [pid 6315] [client 203.0.113.2:36203] script not found or unable to stat: /usr/lib/cgi-bin/
Plesk does not add the ScriptAlias directive for /cgi-bin/ if the application from Application Catalog is installed in the Document Root directory. This behavior is a requirement of the APS Standard, which was created to prevent the corruption of the /cgi-bin/ directory of existing applications on a domain. That is why when an application is installed from the Application Catalog, ScriptAlias is removed from domain's configuration file.
Define ScriptAlias directive manually:
  1. Log in to Plesk.
  2. Navigate to Subscriptions > example.com > Apache & Nginx settings > Additional Apache directives.
  3. Add the desired location for /cgi-bin/ to Additional directives for HTTP and Additional directives for HTTPS:
    CONFIG_TEXT: ScriptAlias "/cgi-bin/" "/var/www/vhosts/example.com/httpdocs/cgi-bin/"
