- Apache 2.4 without nginx is used.
- Site shows Server Connection Timeout:
CONFIG_TEXT: ERR_CONNECTION_TIMED_OUT
In
/var/www/vhosts/system/example.com/logs/error_log
below error can be found:CONFIG_TEXT: [Wed Jan 31 05:50:47.216137 2018] [proxy_fcgi:error] [pid 22487:tid 139703407867648] (70007)The timeout specified has expired: [client 203.0.113.2:55437] AH01075: Error dispatching request to :, referer: http://example.com
- Domain access log contains a lot of entries that IP/IP's tried to access site or particular page:
# cat /var/www/vhosts/system/example.com/logs/access_log |cut -f 1 -d ' '|sort|uniq -c|sort -nr
5319 203.0.113.3
3815 203.0.113.4
Site or page is being abused.
Block IP's that are trying to abuse site.
Plesk > Domains > example.com > Apache & nginx Settings > Additional directives for HTTP:
CONFIG_TEXT: <Directory "/var/www/vhosts/example.com">
Options All
AllowOverride None
<RequireAll>
Require all granted
Require not ip 203.0.113.3 203.0.113.4
</RequireAll>
</Directory>
