- Plesk for Windows
How to create hourly backups in Plesk?
An hourly backup task can be created using the pleskbackup
utility and Plesk Scheduled Tasks (Cron jobs). Plesk hourly backup tasks can be created by Plesk administrator only.
To learn more about the pleskbackup
utility and its options, visit:
For Plesk on Linux: pleskbackup: Backing Up Content and Configuration
For Plesk on Windows Server: pleskbackup.exe: Backing Up Content and Configuration
Examples of hourly backup tasks
In this example, we are creating the Plesk backup task that will create a full backup of the domain example.com with the comment "Hourly backup" every hour.
In Plesk, go to Tools & Settings > Scheduled Tasks and click Add Task.
Fill in the fields and click OK to create the task:
Note: The command path to the
pleskbackup
utility must be full. Plesk command aliases (e.g.plesk bin pleskbackup
) do not work with Plesk Scheduled Task.-
For Plesk on Linux
Task type: Run as command
Command: /usr/local/psa/bin/pleskbackup domains-name example.com --description="Hourly backup"
Run: Hourly
System user: root
Command: C:\Program Files (x86)\Plesk\bin\pleskbackup
with arguments: --domains-name example.com --description="Hourly backup"
Note: The path to the
pleskbackup
utility may vary. -
Run: Hourly
System user: Plesk Administrator
In this example, we are creating the Plesk backup task that will create a full backup of the domain example.com with the comment "Hourly backup" every 3 hours.
pleskbackup
For Plesk on Linux
Run: Cron style 0 */3 * * *
This cron value will run the task every 3 hours. Change it to your own value if necessary.
System user: root
pleskbackup
utility may vary. -
- System user: Plesk Administrator
As an alternative solution, use the Acronis Backup extension, which allows to set up hourly backups in the Acronis backup console:
