Articles in this section
Dovecot fails to start after upgrade to Plesk 17.8 on Proxmox: Failed at step NAMESPACE spawning /usr/bin/doveadm: Invalid argument
kb: technical
  • Plesk Onyx 17.8
  1. Apparmor is not installed:
    # aa-status
    apparmor module is not loaded.
  2. Plesk is running on Debian/Ubuntu in Proxmox virtual environment:
    # plesk bin server_pref --get-server-info 2>&1 | grep virtual
    "virtualization": "lxc",
  3. Dovecot fails to start after upgrade to Plesk 17.8:
    CONFIG_TEXT: Active: failed (Result: exit-code) since Mon 2018-04-23 11:59:33 CEST; 2s ago
    Docs: man:dovecot(1)
    http://wiki2.dovecot.org/
    Process: 11856 ExecStop=/usr/bin/doveadm stop (code=exited, status=226/NAMESPACE)
    Process: 11855 ExecStart=/usr/sbin/dovecot -F (code=exited, status=226/NAMESPACE)
  4. The following error is logged to journald:
    # journalctl -f
    systemd[11361]: dovecot.service: Failed at step NAMESPACE spawning /usr/bin/doveadm: Invalid argument
Unclear.
  1. Connect to Plesk server via SSH
  2. Create the directory for drop-in configuration:
    # mkdir /lib/systemd/system/dovecot.service.d/
  3. Create /lib/systemd/system/dovecot.service.d/pleskfix.conf file with the override configuration:
    CONFIG_TEXT: [Service]
    PrivateTmp=false
    ProtectSystem=false
    PrivateDevices=false
    NoNewPrivileges=false
  4. Reload systemD services:
    # systemctl daemon-reload
  5. Start the Dovecot service:
    # systemctl start dovecot
Additional information
If Apparmor is used, check this article.
