Plesk for Windows
kb: how-to
Plesk for Linux
ABT: Group B
- Plesk for Windows
How to manage the PHP variable max_input_vars
in Plesk?
The variable can be set for one domain, or globally for all domains.
One Domain
Log in to Plesk
Go to Domains > example.com > PHP
Add
max_input_vars
with the desired value to Additional configuration directivesmax_input_vars = 3000
Press OK to save the changes
All Domains
- Log in to Plesk
- Go to Tools & Settings > PHP Settings > <Desired PHP handler>
- Switch to the php.ini tab
- Search for
max_input_vars
, remove the;
in front, and enter the desired value - Press OK to save the changes
