Articles in this section
How to manage the PHP variable "max_input_vars" in Plesk
Plesk for Windows kb: how-to Plesk for Linux ABT: Group B
  • Plesk for Linux
  • Plesk for Windows
How to manage the PHP variable max_input_vars in Plesk?
The variable can be set for one domain, or globally for all domains.
One Domain
  1. Log into Plesk
  2. Go to Domains > example.com > PHP
  3. Add max_input_vars with the desired value to Additional configuration directives
    max_input_vars = 3000
  4. Press OK to save the changes
All Domains
  1. Log into Plesk
  2. Go to Tools & Settings > PHP Settings > <Desired PHP handler>
  3. Switch to the php.ini tab
  4. Search for max_input_vars, remove the ; in front, and enter the desired value
  5. Press OK to save the changes
