Articles in this section
How to add headers to Plesk Web Interface pages?
kb: how-to Plesk for Linux ABT: Group A
  • Plesk for Linux
How to add headers to sw-engine delivered pages?
For instance:
CONFIG_TEXT: X-XSS-Protection
X-Content-Type-Options
Strict-Transport-Security
  1. Connect to the server via SSH;
  2. Modify /etc/sw-cp-server/conf.d/plesk.conf using any text editor (for example vi) and add required values to the server section:
    CONFIG_TEXT: server_names_hash_bucket_size 64;
    server {
    listen 8443 ssl;
    listen 8880;
    listen 127.0.0.1:8880 default_server;
    include conf.d/*ipv6_ports.inc;
    ssl_certificate /usr/local/psa/admin/conf/httpsd.pem;
    ssl_certificate_key /usr/local/psa/admin/conf/httpsd.pem;
    # XSS Protection
    add_header X-XSS-Protection 1;
    add_header X-Content-Type-Options "nosniff";
    add_header Strict-Transport-Security "max-age=31536000; includeSubDomains" always;
    include conf.d/*plesk.inc;
    include conf.d/*wpb.inc;
    Note: The above values are just an example. Syntax of the headers may be obtained from the nginx manual.
  3. Restart sw-cp-server process:
    # service sw-cp-server reload
8 comments
Date Votes
  • X-XXS-Protection "1; mode=block" policy is already enabled and can't be overwritten using it.
    How can I do that?
    Thank you
  • Hello Alex,
    Is it already enabled for Plesk pages (Plesk GUI) or your actual websites?
  • Hi, Anton;
    I was talking about Plesk GUI. Even without the line add_header X-XSS-Protection 1; mode=block; on the /etc/sw-cp-server/conf.d/plesk.conf, when you look to the Plesk interface on the console or using an external checker like securityheaders.com it appears the X-XXS-Protection header enabled. If I add the line
    add_header X-XSS-Protection 0;
    it didn't overwrite the other one. How can I change it?
    Thank you
  • Hello Alex,
    Thank you for the clarification.
    XSS-Protection header is indeed hardcoded into Plesk's PHP engine. To remove or modify it, you can use the following panel.ini directives:
    [security]
    xssProtection.enabled = true // add or not header
    xssProtection.blockMode = true // add or not mode=block
    xssProtection.reportingUri = false // add report block with uri from this param
  • Thank you so much, Anton!
  • Can you advise on adding Content-Security-Policy header and default values for Plesk Web Interface pages?
  • Hello,
    For CSP, what's values are suggested to use in 8443 - plesk panel?
