Articles in this section
Large spaces appear between lines in Plesk Code Editor when Atomic Secured Linux extension is enabled
kb: bug Plesk for Linux
  • Plesk for Linux
  • When opening a file in Plesk Code Editor, large gaps appear between the lines:
  • The Atomic Secured Linux extension is enabled in Plesk at Extensions > My Extensions > Atomic Secured Linux.
Atomic Secured Linux extension bug with ID EXTCERT-3863, which has been fixed in version 1.5-1.
Update the Atomic Secured Linux extension: How to manage Plesk extensions (install, disable, remove, update)
Previous W/A:
  1. Connect to the Plesk server via SSH.
  2. Create a backup file of /usr/local/psa/admin/htdocs/modules/asl-installer/global.css:
    # cp -a /usr/local/psa/admin/htdocs/modules/asl-installer/global.css /usr/local/psa/admin/htdocs/modules/asl-installer/global.css_orig
  3. Open the file in a text editor. In this example, we are using the vi editor:
    # vi /usr/local/psa/admin/htdocs/modules/asl-installer/global.css
  4. Remove the following line:
    CONFIG_TEXT: pre { height: 400px;overflow-y: scroll; }
  5. Save the changes and close the file.
