Plesk for Windows
Plesk for Linux
kb: technical
- Plesk for Windows
A website does not load over HTTPS with one of the following errors in a web-browser:
CONFIG_TEXT: ERR_CONNECTION_RESET
CONFIG_TEXT: PR_CONNECT_RESET_ERROR
- Over HTTP the website works fine.
SSL/TLS support is disabled at Domain > example.com > Hosting & DNS > Hosting settings.
- Log in to Plesk.
- Go to Domain > Dashboard tab > example.com > Hosting & DNS > Hosting settings.
Enable SSL/TLS support.
- Apply the changes.
